Helicobacter pylori genome and next-generation sequencing
One of the first bugs to be sequenced, H.pylori has a small genome (1.6 MD) befitting its lifestyle in a hostile acidic mucosal niche. Of the 1500 genes, 750-1000 are essential, the others are different in each strain. Hp has an "open pan-Genome" which means the more strains you look at the more genes you will find - i.e. you will never have a complete set of all its possible genes!
Moderators: Toni, barjammar, stomach
stomach
Post by stomach »
Here is a good review about how we can take advantage of next-generation cheap and massive sequencing tech... :idea:
Engstrand-2009-How will next-genera.pdf
(67.3 KiB) Downloaded 460 times
User avatar
barjammar
Re: Helicobacter pylori genome and next-generation sequencin
Post by barjammar »
Here is an article you sent me about "The Sequence Factory" which is the BGI in Shenzen. I am using it to test the upload of a pdf less than 512 Kb.
THE SEQUENCE FACTORY.pdf
Nature news article about the BGI
(1.72 MiB) Downloaded 647 times
Thumbnail Image of Article
Return to “Genomics of Helicobacters”
