H Pylori
Re: H Pylori
I called the doctor office and they prescribed me another 5 days supply of Amoxicillin and also the 20mg Omeprazole to take twice a day.
I can buy Pepto Bismol over the counter as it is a normal/popular medicine, so that is good news. I'm planning to get the 262 mg caplet. Do you have a recommended dosage to take for the 10 days? I'm guessing one 262 mg caplet twice daily. Thanks.
Also, does the medicine need to be taken together? Can I schedule it like this?
Amox - 4 times a day - 6 AM, noon, 6 PM, midnight
Clar and Ome- twice daily - 9AM, 9PM
Re: H Pylori
we normally prescribe 240mg bismuth four times a day.
How to take the medicine?
you can take them together.
most importantly is the same type of medicine is spread out evenly. for example. twice a day, you can take it 9am and 9pm (every 12 hrs).
Re: H Pylori
I'm on my 6th day of the therapy and haven't got any serious side effect. I did have minor stomach pain/weirdness and burp the first couple days. It seems I'm back to normal on the third day. I read that NAC could break the biofilm and that low Nickel diet will also help, so I add that to my regimen. Here is what I did so far:
I took NAC 1000 mg once a day (I think it might be better to take 600MG twice a day) and also went on a low nickel diet for 14 days before I start the antibiotic therapy.
Then I start the 10 days Quadruple Therapy and also continue to go on a low nickel diet. I also add probiotic. I took the probiotic once a day for the first 3 days, then twice daily afterward.
6 AM - Amoxicillin - 500mg, Pepto Bismol - 262mg, Omeprazole PPI - 20mg
9 PM - Probiotics
12 PM - Amoxicillin - 500mg, Pepto Bismol - 262mg, Clarithromycin - 500mg
6 PM - Amoxicillin - 500mg, Pepto Bismol - 262mg, Omeprazole PPI - 20mg
9 PM - Probiotics
12 AM - Amoxicillin - 500mg, Pepto Bismol - 262mg, Clarithromycin - 500mg
I'm planning to continue the low nickel diet for another 3 days after the therapy and also discontinue the PPI Omeprazole right after the therapy. I will probably continue taking probiotics and see how it goes. I will periodically update my status and hope this help someone.
9 PM - Probiotics
9 PM - Probiotics
Re: H Pylori
This looks like a good plan. do keep us posted.
Re: H Pylori
Plotun wrote: ↑Wed Nov 25, 2020 5:44 pmHelico_expert wrote: ↑Wed Nov 25, 2020 11:41 amThe real mechanism is unknown. But the theory is that H. pylori infection can attract a lot of inflammation in the stomach. These inflammation cells are the culprit for "mass destruction" in your stomach.
When the stomach is under lots of inflammation, lots of destruction happening everywhere, the mucus producing cells get destroyed (no mucus production, hence ulcer); and the acid producing cells get destroyed (hence, less acid).
so as there is no more H. pylori, the inflammation cells gradually retreat. the cells are growing back. but there is no control how many cells of which type is growing back. it all happens randomly and then gradually your body will adjust the amount of cells of each type.
Thank You. I have an additional question.
I'm doing a retest in two weeks. Since I use olive oil when preparing meals, can this affect the test results or it's impact on tests results is negligible?
And is it possible that active h.pylori infection reflects on the number of leukocytes, increasing leukocytes in blood? Last time when I did blood tests, at the beginning of infection, I've had leukocytosis.
My WBC is not high, I'm currently taking antibiotics for h pylori.
Re: H Pylori
I finished my 10 days therapy 4 days ago. I stopped taking PPI and continue to take probiotic. I have been getting mild burning sensation in my stomach and also burping an hour after I ate. I didn't encountered any noticeable symptom during the therapy. Is this because I stopped taking PPI, so the acid level rise? Or is because I have low stomach acid? I need to test this to make sure before moving forward.
Re: H Pylori
You can try to continue PPI and see if that improve your symptoms.
PPI is quite safe to take.
but you will need to stop PPI for at least a month and repeat the breath/stool test to confirm your HP eradication.
Alternatively, you can switch to famotidine or any H2 blockers. They will not interfere with the follow up test. You can continue famotidine until the night before the test.
Re: H Pylori
I ended up not using PPI as the symptom was minor and kind of went away after a while. I continued to take Probiotic. I still have minor burp, especially when I woke up in the morning. It is much better now.
I'm due for the breath test next week and the doctor office told me not to brush my teeth and rinse my mouth in the morning. I think it's kind of extreme. I read that brushing teeth should be fine. What do you think? Thanks.
Re: H Pylori
yea, brushing teeth and rinsing mouth can reduce the risk of false positive.
however, the above activity will only work if you are constantly having borderline result. The theory is suggesting that the oral microbiota has contributed to the low positive result.
anyway, I am glad to hear that your condition improved.
Re: H Pylori
The breath test came back negative, so that's great news. I feel mostly normal, except for minor burp here and there.
Anything else you would like to recommend? Thanks for your help!!
