Reinfection? - Pls advise Helico Expert
Re: Reinfection? - Pls advise Helico Expert
Hi helico expert
After my treatemnt i had my 1st endoscope and it stated prominent intestinal metaplasia detected 15 months later it was not seen by gastro dr or biopsy only mild chronic gastritis and to make another endoscope in 2 yrs
so this non metaplasia observation is made from visual or histology?
nevertheless, it's a still a good progress that if it cannot be seen by naked eyes.
Hi
It was done by histology samples being sent away got results last thursday
Then the result is trustworthy. Very glad to hear that your IM is gone.
Thanku so much for everything u are truly amazing i read im is reversable but just didnt think mine would reverse i was to be honest in shock
Very happy to hear this! I have read that IM is not reversible etc. but seems our body's capacity to heal is tremendous.
Hi Helico expert. I had H. Pylori and did the triple therapy with Amox, Clarithro & Protonix. I finished and waited two weeks after the protonix to do the breath test, it came back negative. It's been 6 weeks since my triple therapy. Do I need to do another one after a month off of antibiotics? Or should I just be happy that the first treatment worked? Also, I still don't feel hungry most of the time and have lost 25 pounds during this 3 month ride. Stomach still gets a little discomfort and I burp so much, my Primary doctor says it'll take time and just told me to take Omeprazole for 14 days to help with acid. Thanks for any information you can provide.Helico_expert wrote: ↑Sat Oct 05, 2019 4:45 pmstool test is as accurate. But all test is relying on good technician who knows what they are doing.
two weeks without PPI is enough for the stool test.
Breath test is usually quite accurate. However, it would be good to know how negative is your negative result.
I dont think you need to check again within 6 months. I agree with your doctor, give yourself a bit of time to recover. and Omeprazole too. take it if you have acid problem.
How come test was done 2 weeks after treatment ended? I have read it must be minimum of 4 weeks after antibiotics to get an accurate result?willards1 wrote: ↑Fri Nov 29, 2019 3:13 pmHi Helico expert. I had H. Pylori and did the triple therapy with Amox, Clarithro & Protonix. I finished and waited two weeks after the protonix to do the breath test, it came back negative. It's been 6 weeks since my triple therapy. Do I need to do another one after a month off of antibiotics? Or should I just be happy that the first treatment worked? Also, I still don't feel hungry most of the time and have lost 25 pounds during this 3 month ride. Stomach still gets a little discomfort and I burp so much, my Primary doctor says it'll take time and just told me to take Omeprazole for 14 days to help with acid. Thanks for any information you can provide.Helico_expert wrote: ↑Sat Oct 05, 2019 4:45 pmstool test is as accurate. But all test is relying on good technician who knows what they are doing.
Even Breathtek instructions indicate “ 4.4 False negative test results may be caused by:
• Post-treatment assessment with the BreathTek UBT less than 4 weeks after completion of treatment for the eradication of H. pylori”
https://www.otsuka-us.com/media/static/ ... 1575120851
My primary doctor said that the breathe test results were accurate after being off the PPI for two weeks, which is the reason why I tested so early. I just wanted to confirm that with Helico Expert among the other things in my post.ankiwo72 wrote: ↑Sat Nov 30, 2019 9:36 pmHow come test was done 2 weeks after treatment ended? I have read it must be minimum of 4 weeks after antibiotics to get an accurate result?willards1 wrote: ↑Fri Nov 29, 2019 3:13 pmHi Helico expert. I had H. Pylori and did the triple therapy with Amox, Clarithro & Protonix. I finished and waited two weeks after the protonix to do the breath test, it came back negative. It's been 6 weeks since my triple therapy. Do I need to do another one after a month off of antibiotics? Or should I just be happy that the first treatment worked? Also, I still don't feel hungry most of the time and have lost 25 pounds during this 3 month ride. Stomach still gets a little discomfort and I burp so much, my Primary doctor says it'll take time and just told me to take Omeprazole for 14 days to help with acid. Thanks for any information you can provide.Helico_expert wrote: ↑Sat Oct 05, 2019 4:45 pmstool test is as accurate. But all test is relying on good technician who knows what they are doing.
