Page 3 of 7
Posted: Wed Aug 28, 2019 3:43 am
by Sajal
I have been meaning to ask whether I should go for PBMT therapy despite the fact that here in India metronidazole resistance is quite high ( above 50 percent). Infact metronidazole is considered the least sensitive antibiotic for h pylori.
I have read that tetracycline and bismuth can overcome metronidazole resistance. So should I give PBMT a try or consider other antibiotics therapies like PBAT or PBAF?
I would like to go for the therapy with higher prospect of eradication.
P.S.– have done unsuccessful clarithro- amox based triple therapy.
Posted: Wed Aug 28, 2019 1:17 pm
Yup. PBMT or PBAF are both good.
Posted: Wed Aug 28, 2019 11:08 pm
by Sajal
My GI has prescribed the following:
Esomeprazole 40 mg bid
Bismuth subcitrate 120 mg qid
Metronidazole 800 mg tid
Tetracycline 500 mg qid
Amoxicillin 1g tid.
I haven't heard of such combination. It seems pretty hard as it includes 3 antibiotics+ ppi+ bismuth and would have too many adverse effects. Moreover, I am also concerned about the dose of metronidazole.
Posted: Thu Aug 29, 2019 5:48 am
we gave something similar to extremely case before. However, I agree that metronidazole is a bit high. Do check with your doctor, he may be more experience than us in this combination.
Posted: Thu Aug 29, 2019 4:58 pm
by Sajal
Is it like adding Amoxicillin in the classic quadruple therapy i.e., PBMT therapy gives higher cure rate? If not, what is the purpose of adding an extra antibiotic to a standard regimen?
I think Amoxicillin has been added due to high metronidazole resistance here in India. Can Amoxicillin along with tetracycline be able to eradicate h pylori despite the fact that my h pylori strains are resistant to metronidazole?
Should I take it for the whole course of 14 days or I can stop it after 7 or 10 days?
Doctors here doesn't care about explaining anything to the patients. This is why your suggestions are very important.
Thankyou.
Posted: Fri Aug 30, 2019 6:34 am
more antibiotics = higher cure rate = more side effect
so, as long as you can tolerate the side effects, it's a good treatment. Your doctor will be responsible for your overall health and condition. So call him if you experience very bad side effects.
Posted: Sat Oct 05, 2019 12:20 am
by Sajal
Last therapy I took was a classic quadruple therapy i.e., metronidazole, tetracycline, bismuth subcitrate, esomeprazole plus amoxicillin. So basically it was rather penta therapy.
I haven't heard of such combination. Also, I have heard that Amoxicillin and tetracycline should not be used together as it hampers each other's efficacy. Is it true?
Posted: Sat Oct 05, 2019 4:49 pm
Yea, we use that combination before. It's ok.
amoxicillin and tetracyclin is a funny combination. The outcome differ from reporters. The success rate range from 40-90%. Not sure why. anyway, in your penta treatment, there will be other antibiotics that will work.
Posted: Thu Oct 31, 2019 7:36 pm
by Sajal
My follow-up test(RUT) came positive today.
Last abx: classic bismuth based quadruple therapy along with Amoxicillin.
Can someone please tell me where can I have antibiotics susceptibility test here in India?
Posted: Tue Jan 28, 2020 3:43 am
by Sajal
Hi...
2 months after completing quadruple therapy I went for follow up test and was tested positive for h pylori by histopathology and RUT. I again waited for around 2 months and over this period I did not take any medicine( not even ppis). Thereafter I went for antibiotics susceptibility testing which was negative. Also, histopathology could not detect h pylori.
I am confused. How come the bacteria is eradicated without taking any medications for it. My symptoms have not been subsided. I understand that negative culture does not always mean that you do not have h pylori. Also, it is not used as a means of detection of h pylori. However, histopathology was also negative and I have heard that it is considered as a gold standard test for detecting h pylori.
