Symptoms after H. Pylori eradication
Posted: Fri Sep 18, 2020 8:35 pm
by Achille1977
I was diagnosed with H. Pylori and did the breath test that is positive in February 2020. So I did the triple and quadruple therapy. In June 2020 after the therapy I did the endoscopy and the breath test again and they have been negative.
The problem after H.Pylori eradication I have been experiencing the same symptoms: gastritis, bloating, insomnia and my doctor prescribed me firstly Pantoprazole but it reduced my vitamin B12 and worsened my insomnia So I went back to see my doctor again and he changed the Pantoprazole to famotidine but famotidine also reduced my vitamin B12 level.
Ma question: what can I do next? What medication will help me to heal?
Re: Symptoms after H. Pylori eradication
Posted: Sat Sep 19, 2020 10:30 am
if your H. pylori is indeed negative, then healing is depending on 1. the damage done and 2. your recovery condition.
Did your endoscopy report mention any abnormality?
I assume you are still young, so your healing is still good. Some people, after eradication of H. pylori, the symptoms can persist a little while. It takes time for the inflammation to go away, and then your stomach can gradually return to normal.
However, there is a small group of people, H. pylori has done some permanent damage, the healing can be difficult.
Posted: Wed Sep 23, 2020 3:47 am
by Achille1977
Thank you for your response.
The endoscopy report mention the following:
1- presence of a small focus of pyloric metaplasia which could be suggestive of a slight peptic duodenitis
2- Antral-type gastric mucosa with chronic inactive gastritis
I’m 47 years old and I don’t know if the healing will take a long time
My question was as the two medication reduced my vitamin B12 and worsened my insomnia what medication can I take then?
Posted: Wed Sep 23, 2020 8:17 am
Can you take B12 supplement?
famotidine is a good alternative to pantoprazole.
47 years old is still young. inflammation can take some time to recover.
Posted: Fri Sep 25, 2020 6:59 am
by Achille1977
Hi Helico Expert
The problem is that apart from reducing my vitamin B12, those medications worsen my insomnia.
Posted: Fri Sep 25, 2020 8:48 am
yea, insomnia can be tough. You probably need to speak to a sleep specialist. Cant help you much with this problem here.
