Please I really need help
koteo
Post by koteo »
Hello everyone.
I've been for a while burping. On July 23rd I mostly had a syncope after I felt 2 spasms in my left chest , that I don't know if it's related to pylory (cardiology's sais it's ok). After that I had a lot of stress, panic attacks, and then I got better.
At the end of August I started h pylori treatment with pylera after I was diagnosed. It went well at the beginning, but I need to go to the toilet a lot of times every day and I lost 5kg+/-. The last pylera day on September 4th I was very weak and very very anxious and with dehydration signs so I went to ER. They checked everything and told me it was a gastroenteritis due antibiotics.
The weight lost also stressed me a lot, as I lost 5Kg in 10 days.
I did a endoscopy and the result was overall good but in th biopsy says I had a bit of inflammation in the mucosa.
My stomach doesn',t hurt, maybe only a bit after I eat or when I'm hungry.
The problem is that the last week I started to have spasms on the muscles, mainly in the legs but on other parts of the body too.
My anxiety raised A LOT after treatment and I'm very afraid and even can't think in other things or stay focused at work.
My life was perfect until I had that episode on July 23rd, but now it got much worst after pylera!!it looks like it killed me in many ways.
Please I will appreciate very much if someone can help me or any doctor that I can consult online because I live in Spain.
Thank you so much.
koteo
Re: Please I really need help
Post by koteo »
Any help, please??
Do you know if you still have H. pylori? if you have not done a follow up test, maybe you need to get it done.
koteo
Post by koteo »
Helico_expert wrote:
Sat Sep 25, 2021 10:13 pm
Hello, I have a new test on October 4th. They did me a gastroscopy on September 13th and was negative on h pylori then, but I will do the a breath test on October 4th.
Could I take probiotics until the test?
I was more concerned about the muscle spasms.
Thank you so much.
the endoscopy is probably accurate enough. but it'll be good to have a second test to confirm the result.
you can take probiotics until the night before breath test.
the spasm may not be because of H. pylori. it's not a typical symptoms reported.
what about your family member that living under the same roof? have they been tested and treated?
koteo
Post by koteo »
Sun Sep 26, 2021 10:44 am
They are going to be tested too.
Thank you.
koteo
Post by koteo »
And what about the weight loss during pylera? I was on 75,5k at the beginning of pylera treatment, at the end I was at 70kg, but I'm having issues to recover weight/muscle lost on those days after mostly 3 weeks.
Thank you so much.
The side effects of antibiotics usually wear off within a week.
Usually after eradication of H. pylori, the stomach condition and appetite would gradually improve and the patients would put on some weight.
