Diet question and my h.bacter story
Re: Diet question and my h.bacter story
Hi Helico
As per my previous posts on this forum I was suffering from high stomach acidity since June 2020. Was tested for helicobacter positive during an endoscopy in Oct 20 (but apparently there was no inflammation). Went through two 7 day antibiotics and ppi treatments with the second completing in January 21. Continued omeprazole for a month thereafter. Since Mar 21 I have been completely off ppi and in mid March my stool test also came back negative for h pylori. Symptoms have also improved a lot since
However I still get bouts of silent acid reflux symptoms mainly tightness in the throat usually after eating. What could be causing this? What is the relationship between acidity and throat tightness?
Also since the infection in June 20 I have lost about 15kg. Although I have started to eat better since March still not gained any weight. How long does it take to gain back 15kg after eradicating h pylori with post treatment syndrome?
I have to say that I did manage to fast in Ramadan which ended yesterday. Strangely I did not suffer from acid reflux during the day only slightly after breaking the fast in the evening after having food. I was expecting other way round.
As always much appreciate your views
some damage may be permanent. you can try some H2 blockers, such as famotidine, to control your acid.
Thanks Helico_expert
Because my first eradication treatment failed i keep having doubt that whether the second eradication treatment wad successful. Although my acidity symptoms has more 80% reduced since the end of the second treatment in January, I have off ppi since March and also had a stool test negative for h pylori in March.
With all of the above and also that I was able fast for nearly 16 hours daily in Ramadan do you think I have eradicated the bacteria?
I think the best way is to get a breath/stool test done. While most people have their symptoms relieved immediately after H. pylori treatment. That does not mean H. pylori is eradicated. Many, including doctors, refer the symptoms relief as "cured", and refer the come back of the symptoms as "reinfection". This concept is incorrect.
So, please proceed with a follow up test to find out if you still carry H. pylori.
As I mentioned i did do a stool test on 19 March which came back negative for h pylori. My eradication treatment ended on 13 January and I was off ppi for 19 days before I took the test.
It's good that your acid symptom has improved significantly.
I cannot guess if you still have H. pylori at present. Given that you got a negative stool test in March and the test is usually around 90% accurate. So it is probably true.
However, you need to make sure that everyone living under the same roof is free of H. pylori. That will prevent you from re-infection.
Just a couple of questions
Can taking probiotic affect the stool test results?
Are breath test results more accurate than stool tests results ? In the UK they give us stool test only because its cheaper for the NHS
Also would taking antacid like Gaviscon Advance affect the stool test results?
probiotics and Gaviscon Advance will not affect stool test result. Just stop them one day before the test.
Stool test is as accurate as breath test.
Hi Helico_expert.
As I said that i'm back to 100%, last week I stopped 20mg PPIs (gradually 3 days yes 3days no).
This week i've been feeling a little bit burning sensation after food again as i'm not on PPIs anymore.
Can 6 weeks of PPIs (20mg) really create Acid Rebound?
What should I do now - I thought I was back to 100% and now burning sensation again after stopage of PPIs. Do I hope that acid rebounds lasts 2 weeks and my acid levels get back to moderation again?
Thank you, Andi
Thank you, Andi
