Your symptoms may or may not be H. pylori related.
but, if you have H. pylori, then eradicating H. pylori has big chance of easing your symptoms.
So, it is important to make sure you are free of H. pylori. You can discuss with your doctor about getting a follow up test to check for H. pylori.
then, if you are truly free of H. pylori, then you can work on the treatment that fix your remaining symptoms.
Hpylori symptoms and treatment advice
