Flare up of symptoms
Moderators: Toni, barjammar
lakhani
Post by lakhani »
My breath test came negative in March 2020. After a month I was feeling normal with no symptoms.
But now, since last two weeks I am having same hunger pangs that I used to have. Sometimes I have burning sensation in my stomach.
I am not taking any medication.
Please help
Re: Flare up of symptoms
have you done a follow up test to check if you are still carrying H. pylori?
lakhani
Post by lakhani »
No I haven't
Then you should go find out if you still carry H. pylori. without removing H. pylori, the recovery is almost impossible.
lakhani
Post by lakhani »
Thank you
lakhani
Post by lakhani »
Hi, h pylori test returned negative. But I am still suffering from mild symptoms.
Plotun
Post by Plotun »
lakhani wrote:
Wed Jan 13, 2021 5:01 pm
I'm suffering too, 2 months after eradication, my only persistent symptom is burning sensation. It takes time to heal, sometimes months. Just be patient.
CheerfulSatchel
Post by CheerfulSatchel »
@Plotun are you taking any PPIs? I'm on Protonix 40mg a day, things are getting better albeit veeeeerrrryy veeeeeerrry slowly.
I also get the burning sensation, flare ups, and episodes of nausea.
Plotun
Post by Plotun »
CheerfulSatchel wrote:
Thu Jan 14, 2021 1:42 am
I was on Rabeprazole 20 mg for 3 weeks and stopped It yesterday because side effects: stomach aches and gnawing pain. I don't want to take PPIS anymore, they reduce burning sensations but I get stomach aches while on PPIS. I get used to burning sensations.
if you do have acid problem, you will need PPI to protect your throat and teeth.
perhaps you can try reduce the dose or change to other brand?
