Treatment
KristinaKuridza
Treatment
Post by KristinaKuridza »
I tested positive for Helicobacter Pylori a few months ago.
The first therapy was Pantropazol, Amoxicillin, and Metronidazole for 5 days, then I waited for a month and did a urea breathing test and it tested positive.
Now my doctor prescribed me Pantropazol and Amoxicillin for 5 days, then I should continue taking Pantropazol with Metronidazole and Clarithromycin for the next 5 days and after that just Pantropazol for another 20 days.
So now reading a lot about it, my curiosity is awakened, is this the right treatment?
Re: Treatment
20 days is a bit too long. I think if it works, it works. there is no need for 20 days. maybe 10 days is enough.
it's important to spread out your medication.
you can also add bismuth to boost your treatment.
KristinaKuridza
Re: Treatment
Thank You for Your reply,
now I started taking Metronidazole and Clarithromycin and i feel nauseous, is that good or bad? And there is an aftertaste in my mouth from the pills for hours, even after brushing my teeth.
During this whole time, since being infected with HP i don't have any pain, my only simptome is bloating but just at evening and during the night, I can't even lie on my stomach.
Re: Treatment
the "bitter", "metallic" taste is because of clarithromycin. The antibiotic get absorbed into your blood stream and flow through your whole system, including saliva. It reminds you that you have antibiotics in your saliva and it's killing all the surviving HP in the mouth (if there is any).
just make sure your PPI dose is high enough. Lots of doctors only give minimum dose of PPI and it's ruining the treatment.
